5/8" to 3/4" adapter...
T.W.Andrews
Cumberland MD
I'm thinking of mounting a torque converter on a 3hp predator engine by tack welding a shaft adapted so the key will not strip off.. any thoughts
Do not weld, you will hate yourself by some means later. If anything put some locktite to hold the sleeve.
Edit: I just read the manual it is 5/8". Thats bizarre....
for that price I would sell it and buy a 212cc, it will need no modifications and has alot more power right off the bat.
porsche930dude
Upstate, NY
you can cut the sleve in two pieces and use two keys oposite from each other to adapt it up . then just use the bolt to hold it all in
rmm727
Brookville, PA
I thought that with those adapter sleeves, you used a rectangular key. IE instead of a 3/16 x 3/16 key you would use a 3/16 x 5/16 key
But...know that I think about it, you might have to do something like Porsche suggested because with a tav, the key is part of the hub.
T.W.Andrews
Cumberland MD
I'm mounting it in the frame of a mountain. bike... id like to get the low end power and top end speed
of a torque converter... the 212cc would most likley twist the center out of the rear wheel... maybe if I reinforce the center of the wheel with 1/4 plexiglass it would take the torque... the key is made in to the torque converter I don't think locktite would hold.. but if I just tack weld it I could always grind the welds.
OH ok I see, trying to build a motored bicycle??
Should have come off the bat saying what its for. Cool none the less.
There is a few guys that have built something here of that nature. Not alot of that here as we focus on other stuff, but by all means stay and chat about it.
We all like to talk motors and building here so have-atter...
Fill in your profile as to your whereabouts, helps us help you.
T.W.Andrews
Cumberland MD
thanks
thanks.. I filled in some info about myself. I'm makeing motorized bicycle first. then my oldest son (16) and I are going to build a go kart.
