5.5 clone issues (jia ling i believe)
beansdaddy78
JR. Member
Carbondale IL.
hey guys i know if asked questions here and there about this motor, but i finally have it on the kitchen table and ready for some action.
My first question is how do i get this part off of my shaft???
I do not have a gear puller yet. i do have pb blaster and a burnzomatic, but i dont want to screw anything up. I am not sure what is on the motor cover where the shaft goes in and worry about if i get something too hot.
any help would be great.
beansdaddy78
JR. Member
Carbondale IL.
This is the motor that i saved from salvage with a $5 bill. when i emptied the oil, a 1 liter pepsi bottle worth of water/oil combo came out. seeing there was water in there i really would like to open it and go ahead and remove the governer and make sure everything will work when i finally get to try to fire it up. so im guessing i might be posting daily and hoping you guys wont mind and will help me get this thing running so i can swap it out with my briggs 5hp
beansdaddy78
JR. Member
Carbondale IL.
do you have any recommendations on a particular brand of gear puller. and an estimate of the cost? i would hate to go as cheap as possible and get some junk, but if the cheap ones are as good as an expensive one let me know please.
I can't give you any recommendations as, what I have available to me probably isn't available to you & vice versa but, I can offer this insight:
The big difference between cheap & expensive is the grade of materials used to make it &, therefore, the load bearing ability.
Having said that, there is a difference between cheap & inexpensive...
In a pinch, with the right tools, you can make your own. Let me know if that may be an option & I can send you some plans...
beansdaddy78
JR. Member
Carbondale IL.
if you could send me the plans, i would be very happy. if i cant make it i have a buddy who can use my tools and probably make it for me. So yes please do give me the plans, that would be awesome if i could make my own.
beansdaddy78
JR. Member
Carbondale IL.
Dear lord, what happened to the backing plate? Thats the inner hub and idler bushing for a torque converter!!!
I dont know what happened, the guy said it came off a lime green go kart the kind with the roll cage. i never found out why he took it off but or why it stopped working, the guy was in a major hurry to get to the scrapyard.
beansdaddy78
JR. Member
Carbondale IL.
any chance you could show me what it is supposed to look like so that i can see what is wrong with the back plate and parts? please
scarletvw
Minnesota
A lot of autoparts stores will rent you a puller, some will only require a deposit and wont actually charge you anything.
I vote for slice and dice. There's no sense trying to save the parts. By the time you've bought all the other components to the CVT, you've bought and paid for a new CVT anyway. By cutting along it's length (even a hacksaw would do!), you're not having to concern yourself with overheating anything, either.
Ya if its thin enough cut it length wise. You wont get a good bite with the puller anyways, by the looks of things. This also works for a inner bearing race.
Bluethunder3320
if i didnt have a puller, i would pick the engine up by that torque converter piece, and hammer a socket or something that fits inside it to knock it off the shaft.
only hold it a few inches off the ground, because when it breaks free the engine would fall. i recommend holding it over something soft so it doesnt get damaged
does anyone understand me? lol
Swabbster
something that works lots with rusted pulleys and sprockets is an air hammer, hold the engine over some cardboard or sometimes soft about a few inches hold on to the torque converter piece and stick the air hammer inside and jolt it off, don't use heat you will wreck the seal, and keep the brass bushing, they get worn out after a while, being as every part on a comet 30/tav2 can be replaced no worries,
