4cycle engine running on 2mix fuel?
B man
Tecumseh FTW!
Oliver springs,Tn
i was watching a video about a Stihl BR600. the guy was talking about how it was called a 4mix. supposedly it has all the workings of a 4-stroke but uses 2mix fuel for the lubrication. so you never have to change the oil.
any thoughts?
Rustydog2010
NZ Nutta :|
New Zealand
Yep, the company that we maintain their fleet for has some Stihl FS130s.
They are 4 cycles. They have a valve train as well, the only thing is they don't have engine oil. The pre mix gets drawn into the crank case first, this lubricates the bottom end, then it gets pushed though a bypass port up to the head, then the valves do the rest.
We seem to have a lot more problems with these 4 strokes compared to the simple old 2 stroke. They are marketed as never having to have the valve clearances checked or adjusted. They last about 3 months when being used commercially, then just stop! We had one that had been running lean and the crankcase seals had gone.
Jeremy.
B man
Tecumseh FTW!
Oliver springs,Tn
Jeremy.
Yeah those engines do sound kinda sketchy.
sideways
Unfinished projects king.
Perth, Western Australia
any thoughts?
Honda have the same thing on their whipper snipper engines. They're really quite simple, fuel air mix gets drawn into the crank case and the inlet port sucks it out of the crank case into the cylinder. As far as I can tell they combine the worst bits of each engine. They have the extra weight, complexity, lack of power ect of a 4 stroke but still have to mix fuel and you get the smoke and worse emissions ( the burnt oil part anyway) of a 2 stroke. It would also be nearly impossible to achieve more than 100% volumetric efficiency. The advantage is that you have a 4 stroke engine that you can turn upside down.
One of my projects is building an engine like this from an old Briggs mower engine.
Thanks
Hayden
Edit: Ah not quick enough. I've never heard anything good about their reliability, I've heard the Hondas get some incredible carbon build ups on the valves in no time at all. I can't see them ever being any good.
JHen
If you want a 4 cycle that can turn in any orientation then you need a dry sump oil system. Aircraft engines have been using them for ages. Racing engines are using them now to because it increases engine performance a lot.
karl
North east Ohio
The problem is dry sump oil systems are to complicated for a chainsaw or other small engines.
anderkart
Surprise Arizona USA
The Arborist (professional tree trimmer) company I worked for has 2 Stihl Hedge Shears with this type of engines. At first we were like WTF, premix in a 4-stroke??? But they've survived 5 years with probably over 1000 hours of very hard commercial use now. They've always started easy, had plenty of power and we haven't had a single problem in over 5 years and counting now.
DustinWolfe
Meridian, Idaho
:iagree: dont knock it till you try it. im not really a fan of stihl but these engines are actually very reliably if you take care of them just like almost any other engine
Rustydog2010
NZ Nutta :|
New Zealand
Not a fan of Stihl? I think they are the by far the most advanced small engine makers. We have Stihl chainsaws and weedeaters that are 20 odd years old. You cant argue with that. You get what you pay for.
But, like I said above we work on dozens of these premix 4 strokes, they have given us nothing but trouble. These are weedeaters compared to Anderkart's hedge trimmers.
Jeremy.
B man
Tecumseh FTW!
Oliver springs,Tn
Jeremy.
same engine regardless.
Rustydog2010
NZ Nutta :|
New Zealand
Yes, they are properly the same engine, but work in different applications. Different load and usage will all factor to different wear and tear.
Jeremy.
