Won’t start back up changed out oil, gas, spark plug and ignition coil. It has a weak spark when tested. Plz help I love her
Start by resetting the air gap on the coil, 0.30 if you have a set of feeler gauges... if you don't then a piece of paperboard from a cereal box, soda carton, or beer carton will be close enough.
That should help, but if it doesn't the next step I'd suggest for a weak spark is unscrew the spark lead from the coil and the gap, trim 1/4" off each end, squirt some dielectric grease into the coil, and the cap before screwing it all back together.
They do often put a drop or two of superglue to keep them from unscrewing from the coil but it tends to cause more issues than it prevents.
The real question is at what point was there trouble, like what changed before it wouldn't run?
Something else to consider is coil orientation. The factory coil on my 208 was positioned spark lead facing down, when I replaced the coil with one that doesn't have internal resistors and an rpm limit I copied that and had weak/no spark which was corrected by simply flipping the coil over.
