440 2 stroke race go kart project-getting close
Marinetech
Hello guys, so been working on this race kart for about a month now pretty much on my own, but not the first time i have taken on a go fast as i can project. I found this shifter kart for sale and bought it for 400.00 with no engine, brakes, and big ideas. I had this 440 cc 2 stroke snowmobile engine for a ultra light aircraft I was going to put together some day. Seen this kart and that Idea took a walk. After tons of research, I decided that I did not want a CVT or jack-shaft set-up, I wanted a centrifugal clutch like most karts from back in my kid days. Problem was no one made a clutch that could handle 40+ hp. Well i found a couple companies that make clutches for industrial use. Noram clutch makes a TRY-Lobe clutch that holds 18 to 50 hp for 545.00. I bought it, also found out that SBT (jetskiparts) place that makes an electric starter. Converted it from points to electronic (CDI) ignition. Found an original carb on ebay, very nice one to. I got the clutch for Noram and it comes with two belt groove pullys on it, well that will not work, already had a set of 530 chain sprockets and took the clutch to a great machine shop down the street from my boat shop and they went to work on the clutch so i could put a 12 tooth sprocket on the drum of the clutch, 785.00 dollars spent modifying the clutch, it is totally serviceable even after the mods. My final parts should be in on Tuesday and plan on seeing what she can do. I have some pics below of this project coming together. As soon as I run it, i will be hollering at you guys and will give a total cost of the build up to that point.
Knew it was a snowmobile engine from the first pic and before reading a thing.
Should be a potent powerplant for kart. Keep plugging along!
Marinetech
Well guys every time I get a new part for this kart I end up having to make more mods to get things to work together. So here are a couple picks of what I have assembled so far.
Marinetech
FINISHED
WELL GUYS THE END RESUKT WAS NOT DISAPPOINTING! After 4 weeks of build time and 3500.00, I have a Bad M.....F......n Go Kart!
As Soon as I find a Place with nice enough black top or concreate to open it up I will attach video. I have had it up to 60 and 70 mph with a very strong powerband left. Yes powerband just like a race dirt bike, and it sets you back just like my corvette, maybe more Gs. Itshas new front tires and rears will be here Tuesday. It is for sale like every project I build. 90 mph is what the speed calculator came up with at 9999 RPM, this motor will turn mor than that. $4,000 obo.
