420cc Throttle Linkage
Zombient
Junkyard Derelict
Waco, Texas
Anyone have a how-to or pictures on how to bypass the governor
(not remove it, just remove the linkage to it) and connect a throttle linkage to the 420cc Predator? It seems to be a lot different than the 212cc. I can't find any videos or pictures of it :huh:
Thanks!
Poboy kartman
Senior Moments Member
White Settlement Texas
Thanks!
REALLY???? WTF???? Is this a joke?
Joe-405
Enjoying New Projects
U.S.A.
You have to pull the side cover off and remove the plastic gearing setup. But if your not willing to blow it up i wouldnt !!!
Zombient
Junkyard Derelict
Waco, Texas
Nope. Just need to know how to connect the linkage to the throttle.
Hold on Somebody just did this.
Joe405 on his build off posted pics!
---------- Post added at 07:27 PM ---------- Previous post was at 07:22 PM ----------
Post 77
http://www.diygokarts.com/vb/showthread.php?t=32896&highlight=Mini+bike+build&page=4
Also Joe is cool ask him on that thread or send him a PM
What I really need is that little throttle linkage thing there. I need to ask him where he got his setup.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
But dude, you dont want (shouldn't) to just by pass the Governor. It needs to be fully removed.
The internal Governor has plastic parts that cannot hold up to the additional RPMs and will break. Leaving free part to float around inside the engine.
That is why Joe said "are you willing to blow up your engine"
Here is more of Joe's see post #8
http://www.diygokarts.com/vb/showthread.php?p=417959#post417959
Zombient
Junkyard Derelict
Waco, Texas
I will remove the gear. I'm just curious how to connect everything.
With the 212cc it only took a little piece of coat hanger. But this 420cc seems different.
Joe-405
U.S.A.
You might also while your there remove the arm for the governor also. Mine would move freely and hit the counterweight inside which will destroy the engine also. After removing just silicone or jb weld a bolt that fits snugly in the old hole up top.
---------- Post added at 12:02 PM ---------- Previous post was at 11:53 AM ----------
On the newer predator 420cc you have to use this one..........
http://www.pfmparts.com/Predator-42...cing-modification-performance-honda-clone-PFM
