scatteredsun
Thought I'd finally put together a project post.
First off, I know nothing about karts and very very little about engines. I bought a frame off craigslist on a whim because I wanted to learn about it all.
Turns out I got a Tomberlin Crossfire 150r frame. No engine.
After a flurry of research and learning, I decided on a 420cc predator with a 40 series TC (had a lot fun learning all about TC.)
I realized early on that I'm going to have to chop off the engine cage on the swing arm unit. I pulled the swing arm off yesterday and it's going to go under the knife as soon as I have some free time.
The other hurdle I ran into was the factory axle. All the hubs were welded on. This wouldn't do as the sprocket hub was lined up for a tiny 150cc. I got a brand new, keyed, 1" axle and all the parts. They're set to arrive tomorrow.
I just got back from Harbor Freight with a 420cc predator. I found a super coupon that brought the cost down to 299.99. I happened to spot a Hemi model and snagged it.
I'll post a couple pics of the before and one of the engine assembly when it's all done.
I still need to find a welder (anyone in Seattle?) to weld the engine mount plate on.
After the engine and rear axle are all set, I need to bleed the brakes and bolt the seats on. After that, it's time for a test ride!
