So my buddy came over and after watching me ride it...............
We have came to a conclusion that its ignition somewhere. I havent pin pointed it yet but when i do i will let you guys know for sure !
Has anybody else even tried using one of these engines yet ? For some other feedback. Or am i the only one that removed the internal governor and tried it so far ?
---------- Post added at 07:13 PM ---------- Previous post was at 07:08 PM ----------
Does this make sense to anybody...............this is the specs of the coil
YAMADA 188F Generator High Voltage Set,Ignitor,Ignition coil
Technical Parameter:
1. Operating Temperature Range: (-30~105)C
2. Storage Temperature Range: (-40~120)C
3. Operating R.Speed: 250~4200rpm
4. Fly Wheel Magnetic Field Intensity: 1500~1900GS
5. Testing Term: situation temperature 20C, The distance between fly wheel is (0.4±0.1)mm and 3 pins is 6mm
6. Min. Continuous Ingintion R. Speed ≤250rpm
7. Min. Opening Voltage ≥12KV/250rpm;≥16/KV(1000~4200)rpm
8. Ignition Advanced Angle: (22-25)°/(250~4200)rpm
9. High and Low Temperature shoke: Between (-29~125)C, every degree for one hour and after 25 cycles, the original function keeps above 90%
10. Endurance Performance: the temperature 85C and R. Speed 3600rpm, after sontinue 150 hours operating, the original Performance keeps above 90%
11. Open Circuit Performance: Temperature 85C and R.Speed 3600rpm, after continue 150 hours, secondary open circuit keeps above of 90% original one.
12. Shake Performance: 4 hours shock on tridimensional direction with strength 98m/(second*second), the range of frequency sweep is 50~500Hz and after 15 minutes, the original performance keeps above 90%.
