I have a go kart frame that I want to install a stock predator 420cc engine onto. Planning on 20-22" tires, currently has 21" tires. The frame already has a 45 tooth count sprocket on the axle. The engine has a 40 series torque converter (gopowersports.com) attached to it with a 10 tooth output sprocket. Two questions. First, would this setup work fine as is, or am I going to run into problems with these sprocket sizes? Second, what do you think the ideal drive sprocket tooth count would be for this setup? Am I fine not using a jack shaft in this setup? I believe with the frame and engine the kart will weigh in at around 400 lbs, and it's a two seater intended for two adults. I've been playing with app.kartcalc.net, and it seems to think the gear ratio as is is too high and it will burn the belt. I'd love to hear how you would approach this setup for the best experience. I'm fairly new to this.
