OK, so my 18HP engine just received the torque converter i bought.
HOWEVER... the engine shaft does not run the full length of the driver. Is this ok to have the shaft 3/4 of the way into the driver? What should I do with the rest of it...just buy a bolt that threads into the shaft to pull it all tight?
with the driver mounted in the normal direction, it rubs on part of the engine where a pump or something would mount.
Option 1: Mount driver beckwards. Any issues with this?
Option 2: grind down points of contact on the engine.
