One of those clutches needs to be flipped over.
It’s not hydro static thoughI have done a similar project, with a transaxle from a mower. The project is a utility kart for hauling tools and things around the vast MTL campus.
I only get about 10-12 mph tops. The hydrostatic trans from a mower is not made for high speeds. Despite what your calculations say, l don't believe you will ever see 37MPH. Nobody builds a 37 MPH mower. Mowers are designedt a to deliver smooth power @ 2-3 MPH. Your results may vary, however.
I could be wrong, but that is my conclusion. I didexperiment with gearing also.
21,6:1 gearingshou be a clue. Good luck! I can share my (long) joutney to success if a want.
ls it a vertical input shaft?
Can I run reverse spring on the driven pulley? Why does on have to flip?One of those clutches needs to be flipped over.
Understanding hydrostatic transmissions
A hydrostatic transmission (HST) exists any time a hydraulic pump is connected to and dedicated to one or more hydraulic motors. Versatility is achieved by making either or both...www.powermotiontech.com
Ehemmm... Mine did 40 easily.Nobody builds a 37 MPH mower.
Okay thank you, yeah I heard most people will switch out the internals for chain drive and loose the nuetral and reverse part. Do you know the set up you had on there maybe it’s something I can go off of?Something else you may want to consider. We have abandoned this project because the trans cant handle these speeds and it looks like we have the same trans. I think mine just has that goofy MTD CVT on top. We blew the first trans really fast because I didnt switch out the gear grease for gear oil and the second one lasted maybe 5-6 hours of riding with proper lubrication.
You may want to consider another project or be content with the speeds youre getting now. Reliability drops off exponentially the faster you move these transmissions.
You could simply look up the specs of a Craftsman t1000 (consider the fact that I swapped a 14" pully onto the shaft, used a bit longer belt, connected the throttle to the Gov, upgraded the carb a bit) and stop your silliness from showing.Yer ridem mower?
Well, we were talking stock mowers.You could simply look up the specs of a Craftsman t1000 (consider the fact that I swapped a 14" pully onto the shaft, used a bit longer belt, connected the throttle to the Gov, upgraded the carb a bit) and stop your silliness from showing.
Lol sorry, of course I wasnt saying a stock mower goes 37. I read it as, "nobody can modify a mower to go that fast".
I just thought you were jokingly fishing for proof...
View attachment IMG_7341.jpegstill wondering if you can explain to me why I have to flip so I can understand better how this works, I see the shoes on the driven look like they might be going against the belt when being turned would that be enough to stop it from shifting? Also i understand that when the pulleys open the belt will be out of line but that’s just bad for wear as far as I can tellOne of those clutches needs to be flipped over.
So it will work.wondering if you can explain to me why I have to flip
