Chevyloonatik
So ive got a carter brothers mini monster, ive got a 15hp 420cc motor with a 40 series clutch. 703985 belt, red spring in the driven 7 inch, 14 tooth #40 sprocket to a 20 tooth jack shaft then 12 tooth out to 54 tooth at wheel, tire size is 22 inch. Im 190 lbs and the cart is probably around 300lbs. Im having belt issues, i had a newer belt that did some light break inbefore going out for a ride. The belt made it for half the day of riding before it wore down to barely moving. The motor is new and the clutches are new as well. The driven is floating on its shaft so it can keep proper alignment at all times. Anyone have issues like this? Im ready to cut my losses on the motor and drive system in place of a quad motor with gears because belts here in canada are 60 bucks each and i dont want to pay that everytime i take it out
