4 horse briggs engine
Nelson
Maine
I have an older 4 horse briggs and stratton with a tank mount carb. I drained the oil and it was very sludgy and chunky. What would be best to flush out a crankcase? I was gunna put drain oil in it and crank it over, it doesnt run yet, and drain it until its clean. Would this work?
I would put some fresh oil in, run it for a while and then drain and refill again. Do this until you see the oil stays clean
No no no, that won't work... well, it might, eventually...
IMO, your second best option is to drop about a quart of diesel in the crankcase, pull the starter a few times to splash it around a bit then drain it.
Of course, the best option is to tear it open & clean it by hand; this is also the scariest option
I am sure I have heard this advice before, but your method sounds a lot faster than mine
Nelson
Maine
I wanted to tear it open but the end of the shaft looks flared. Even with a puller i couldnt get the clutch off. Ill probs work on it tonight. Thanks guys
