Denny Graham
So.....restoring an old flathead from Dec. 1988. These were common on some of the early
small mini bikes. This one was left out by the neighbor for the G-man and I decided to try
and bring it back to life. It had a badly pitted intake valve so bought a new one and lapped
it and the old exhaust (was in amazingly good shape) in.
the bore was very good, doesn't look like it had been run much, was off a lawn sprayer I'm told.
It's got good compression now and good spark and has a solid solid fuel tank which has been
soaked in white vinegar over night and flushed.
Next, to address the fuel....The Pulse-Jet carb was soaked in Purple Power cleaner in an Ultrasonic
cleaner then washed in hot water and then all passages (that are accessible without drilling out plugs)
were flushed out with CRC Brakleen brake parts cleaner. This carb does not have a removable low speed
'seat' so cleaning is limited to washing out and blowing out of the low speed 'seat' hoping to clear the ports
into the venturi. A new needle was installed, which, has been set 1 1/2 turns out for the initial starting setting.
The main jet casting and jet that dips into the small well is clear, again delicately probed with tip cleaners and
small wire brushes.
The problem here is, the 'emulsion tube' it is set behind the main jet (which is none removable) so there is no
direct access to the tiny holes in the emulsion tube. And again, this was all flushed and blown out as well as could
be done without drilling out plugs.
Now for the problem. The engine starts but only runs for 10 or 15 seconds never getting up to speed and
with the air cleaner off, you can see that there is much liquid fuel pooling in the throat below the choke plate.
Now that it's flooded and dies, when I pull the plug it's wet. So it's clear that there is WAY to much fuel entering
the engine, and with no way to adjust the high speed fuel delivery on these simple carbs I'm at a loss as to why it's
getting to much fuel.
My guess is that the imbedded emulsion tube is possibly clogged since the holes in it would be extremely
small and this might be a reason that lots of raw fuel is being delivered to the venturi and not being mixed
with air for atomization.
Does this sound logical????
Obviously a new carb would fix it but, a new Pulse-Jet from 1988 would be ridiculously expensive, that is,
if you could even find one, and the object is simply to try and save a good little old engine from the scrap heap
without investing to much into it. Which, so far I've only invested $6 in an intake valve, $10 for a carb kit and
another $6 for an air filter......and 100 hours of labor!!!!
So if there are any 'experienced' small engine experts out there who might have any suggestions, I'd appreciate
hearing them.
Thanks,
Denny G
Sandwich, IL
small wire brushes.
hearing them.
Thanks,
Denny G
Sandwich, IL
