3hp Briggs water pump motor
Clayton
Saskatchewan, Canada
Today I picked up a Briggs 3hp water pump that don`t run for $12.50. :sifone: I figure that I have the parts to fix er up and get it running. :D But is there any advice that anybody could give me about working on a 3hp briggsÉ (it is horizontal shaft). :huh:
B man
Tecumseh FTW!
Oliver springs,Tn
well briggs are very reliable and easy to work on. toughest engine i have ever seen. probly wouldnt take much to get it running.
Clayton
Well, the gaskets look good, I just checked em out. I am just gonna fix a sticky valve, and get some spark and I`ll have her running...hopefully.
karl
North east Ohio
The water pumps have threaded shafts. What year is it? You will probally need a carb diaphram, I would get a 4 or 5 pack because they are dirt cheap. If there is points I assume you know how to clean the points and take the flywheel off right?
Clayton
Okay, no I don't know how to take the flywheel off. But the points are the magnetic spots on the flywheel??? I haven't done alot of this yet so I am kinda learning as I go. As for the carb, I think somebody put a carb kit in it a few years ago. But I have a question: the two magnetic spots on the flywheel, only one still in magnetized, is that how it should be?
karl
North east Ohio
If you can tell me what year it is or a pic of the coil I can tell, not all briggs have points
Clayton
It has points, I watched a you tube video how to clean the points with sand paper. I did that, but my problem now is that I need a new ignition coil. The one I have is rusted really bad, and is starting to split apart. Hopefully will get the coil by the end of the week.
My question now is: On a older briggs 3hp, is there only one magnetic spot on the flywheel?
