Since we (as in mostly me) spoiled some other thread, with it
this threads starts a bit abruptly..
essentiall with my (obnoxiously long) reply to frosty's comment below
(if you click the arrow icon next to frosty's username below you'll see the original thread btw...)
I print in ABS 99% of the time (we talked about it just the other day in the other thread
No enclosure needed, no bad smells either!
PRINTING in ABS has nothing to do with BURNING ABS
(if done correctly that is)
ABS was the first (and for quite a while the ONLY printable material)
And close to zero of us had an enclosed reprap
And the ONLY reason for one would be it to act as a heating chamber
(control the cooldown time of the layers for improved fusion)
it prints hotter than PLA but nowhere near any fume temperatures
it can even be at least somewhat flexible if needed be...
(made several one piece tweezers and clamps and such)
BUT: for all I know it's not fuel proof by any means.
Also: nearly impossible to send it overseas for a reasonable fee..
just doesn't make any sense really.
But everyone with a spool of ABS filament and a cheap 200 dollar 3d printer can print you a part.
The point is: what are you expecting price wise?
It is cheap for yourself..
but it takes a looong time to print,
maybe a bit of preparation if you've been printing PLA not ABS originally..
some observation throughout the several hour long print
(in case it fails you do not want to waste more filament)
So frankly, I think a chinese made aluminium cast is a cheaper option really, at least if you are willing to pay the man with the printer for his work even a bit.
So.. maybe I just ask you to make a bold decision:
"buy a cheap printer yourself!"
(really 200 bucks is enough to get a decent FDM printer based on the prusa 3 design)
50bucks for a small spool of ABS
and off you go.
for comparision.. ABS material cost for such adaptor is roughly 3-4 bucks; print time (high res) roughly 8h incl setup I'd say (w/o actually checking atm)..
So 25-30 bucks is not unfairly priced (only charging for setup and post processing if needed)
I bet the chinese can mass produce that cheaper in aluminium
but only ten ideas alike
and you could justify to buy such printer yourself
I do 3D Printing as a hobby... one would need either PETG or ABS to print it and it be durable. ABS is obviously much more durable than PETG but PETG is more flexible and less prone to cracking. With the vibration a small engine puts out I would honestly not recommend it as I can see it cracking. I would recommend aluminium of some sort, like they come in the stage 1 kits you can get from anywhere.
The most popular plastic hobbyist use is PLA and that will last about two seconds on an engine. It is great for indoor use but heat, plus vibration plus sun won't be good for it.
--Daniel
---------- Post added at 08:48 AM ---------- Previous post was at 08:44 AM ----------
For example here is a design on Thingiverse however I am still not sure I would trust it unless yo find someone who can print in ABS. My 3D printer does not have an enclosure so ABS is out of the question plus ABS smells pretty bad when being melted. I have printed with PLA (which is most of my indoor stuffs) and PETG which is what I use when I will use the printed thing in the car. For example I made a cell phone holder and printed in PETG, so far it has stood up to Texas heat.
https://www.thingiverse.com/thing:2569176
--Daniel
and off you go.
I have a hard time just changing the ink in my regular printer!
