so it's been well over a year, and this thread as been used as the "go to" thread for people wanting to use a sled motor in their kart. how about finishing up what you started, so we know how it turned out? thanks!
if dial-up is your issue, simply throw a couple movies on a flash drive and head up to the library to upload them to youtube.
your thread has been an "almost, sort of, if he'd just finish it" inspiration for a lot of us!
It did get finished, the kids were scared of it, I bombed around on it for a bit - then it sat in my drive shed. The last time I went to ride it, one cylinder had no spark. I pulled the mag and something got in there and mangled the one point set. At that point I made plans to pull this set up off the chassis and put a four stroke on it. I have since bought a new electric start 420cc clone (16HP) and a cent. clutch, and several sets of Midget outlaw rims and tires, as well as all components required to convert over to a 1.25" dia aluminum rear axle shaft. Work has not started on it - I bought an ancient bulldozer this summer and my time has been consumed by fixing/operating that.
As far as the the old Rotax set up, it worked like a charm - never tossed or smoked a belt the whole time, never tossed a chain either. Clutch engagement was excellent - just like the sled was. The sled brake setup was excellent initially, but wore out real quick, I'd have to say that a bigger brake on the axle would be a lot better. If I kept it as a sled engine, I would gear it down even further than it is now (too fast, rather have more acceleration and less top speed), and get a good brake set up and a good muffler on it as well.
I encourage anyone who wants an easy fast cart to go ahead and try this method. I won't be posting a video of it running as I'm likely just going to pull the engine off as is and do the swap to the clone. It works great with minimal outside machine work, and labour for the builder. And it is dirt cheap, I got the sled for free, and used the entire drivetrain, brakes, steering column, rod ends etc... the rest is a bit of steel and lawn tractor parts.
I'll be back sometime to post the Rotax Kart rebirth
