Trying to fix up my sons Manco Red Fox gocart. Heres whats going on. This spring the gocart worked good. The belt had a tear in it, but was holding up good the last time we rode it. I decided to by a new belt for it. When I went to take the belt off it was totally destroyed, half the teeth were stripped off. My stepsons rode it and I did not know it. So I put a new belt on. (its a cat99 series TC, takes the 5/8 " wide belt) The new belt worked good for the first 15 minutes, now the new belt slips in the driver pulley from a dead start. Every so often it will grab and the cart will take off. Like its intermediate problem. took the TC apart and cleaned it and only made a slight diference. I see no problems with the inside of the TC. I put 2 new springs on it about 6 months ago. Maybe its the driven pulley thats causing the problems? What can I check on the driven?? The new belt is the exact same size as the old belt. I'm thinking the TC started acting up when the stepsons rode and not giving a crap about tearing it up just kept flooring until the belt stripped.
What can I check to see what the problem could be???
Thanks inadvance!
Thanks inadvance!
