30 Series TC question
aham2003
Cleveland, Tn
I have installed probably 20 of these ebay TC on go karts and mini bikes. Well, installing my latest one, and I come across something not right about this one.
All the other ones the belt is pretty hard to get onto the bronze shaft bearing. You have to exert a little force to get them on.
Well, as you can see in the picture, that is not the case on this one. Has anyone ever seen this happen? It doesnt "ride" on the bronze bearing like it should. Its about half an inch passed it and thats not even putting tension on the belt.
Should I call the seller out on it? Actually, I already have lol. Lets hear your opinions.
aham2003
Cleveland, Tn
The belt says 725 on it by the way. Is this the wrong belt. I am seeing that it should be a 203589A which i found that cross references with a 669 belt.
gegcorp2012
Alabama
I didnt check the belt chart, as the diameter of the driven and the distance between driver and driven goes into picking the belt.
Looks like you nailed it.
Looks like it has a 6" driven pulley, but that belt may be a for a 7"??
