30 series converter
tapkoote
north west USA
any of you guys run 30 series converters with
18X9X8 rears? Is it just going to burn up the belt?
thanks
ya I forgot the other stuff
6 hp clone
54tooth sprocket X 10 tooth
Is that set up too much torque?
tapkoote
north west USA
It's a manco dingo, I see in other posts it's considered heavy. All the eight of cage is gone.
Guess it would work out to 5.4 to one
not too far off 6 to 1 is it?
Personally I would say running 18" tyres with a 5.4:1 ratio is way too high. You will be burning belts a lot faster than if you were geared slightly lower. Try gear for at least 6:1 or higher.
That setup might work....but it is not exactly ideal
