Hi there.I have just bought a 3.5HP Briggs with the model numbers being 80232 0677-03 760517. It still goes really well and hasn't given a problem so far. I haven't had it for very long though. Does anyone know how old this thing is, and if there is a manual around i can get.
I also have a centrifugal clutch that seems to fit onto the shaft, but it is a little tight. Do i knock it on with a hammer or mallet or something. Also, how do you then secure it to the shaft. Is there a bolt or screw that you use. I see the shaft has a hole going through the centre of it as well as one halfway along the shaft. Are these used to secure the clutch some way. You will see in the photo of the clutch that i taped it together, cos the inside piece kept on coming out of the drum. Is that normal. Sorry, i am new to all of this
Thanks for the help.
