rgvkid
Charlie Don't Surf!
So unfortunately, after a few times around the parking lot of teh new Kart build, the 3.5 briggs started to bog down. I was running it without the filter on because i hadn't made the adapter yet. After it died I pulled the rope a few times and played with the adjusting screw all the way in and all the way out. I couldn't tell if it was making a difference. It would start for a bit and sound fine but when i gave it gas it would just bog down then would take a few pulls to start up again. I made the filter adapter plate and mounted the air filter then tried it again. Would run for a bit then bog down again. It would run and then i'd sit on the kart and give it gas, I could hear it bogging but no power out of the engine. I Took the filter off and pulled the plug. The plug was a bit damp so wiped it then scotch brite and put it back in. It started up again after a few pulls, i could feel good vaccum pressure on the air inlet, then i noticed it started blowing smoke back out the air inlet before it would stall.
If its blowing smoke out of the carb inlet, does that mean its getting to much gas?
I pulled out the adjustment screw and scotch brite it, it looked pretty dirty. Also, I gave the carb a thorough cleaning and changed the fuel pump seal before i even started the Kart build.
I'll try cleaning the carb again and the gas tank. There was some rust in the tank and prior to the test run i drained the tank and it was a bit brown from the rust. I'll try cleaning it with some pea gravel today also.
