3.5 briggs engine no torque
NateIngram1
Middleburg, FL
Hi i had a 2hp briggs on my go kart and it had suprisingly well torqu and it was fast and all but i wanted something more powerful so i bought a 3.5 briggs and it has very low torque. the 2hp pushed me around alot better but i dont have it anymore. and if you rev the engine wile your not on it it seems like its right but when you put a load on it it doesnt rev up all the way even though you have it full throttle and i dont know what to do...
souperman000
Westlake Village, CA
I am guessing you have a centrifugal clutch? First thing that comes to mind is gearing. How many teeth on your clutch and axle sprocket. But this could also be an engine problem.
Check your throttle stop screw and see if that may have been turned in a bunch. does the engine run good at idle? Could need a carb cleaning...
NateIngram1
Middleburg, FL
its not my ger ratio because like i said it was fine with my 2hp. its just something about this engine and i cant find it. and it does idle good and its not the throttle stop skrew.
How old is the engine? It may simply be old & tired, in which case, it may need a rebuild... but that's a worst case scenario
Start with a good old fashioned carb cleaning. Make certain the main jet is completely clear. After that, replace the spark plug with a clean new one, and do a plug read to make sure it's fuelling properly.
NateIngram1
Middleburg, FL
The engine is old. and i did rebuild it. but it was simply the pressure in the tank fixed by just drilling a small hole in the gas cap
Bluethunder3320
i was working on a snowblower before that i couldnt figure out why it ran like **** with no power and kept dying
turned out the gas cap vent was clogged. easy fix
