2Cycle Question
briggsman
Does any one no were to pull vaccum from on a yamaha 125cc engine for a vaccum operated fuel pump?
thanks for any help you can give!
Kenny_McCormic
Kartless....
Michigan Troll
You can pull from the intake(preferably between the carb and engine but air filter/ carb should do). Or drill and tap the crankcase(requires disassembly).
briggsman
Thanks for the info Kenny, So i guess ill find somewere in the intake to put a fitting at. hopefully there is enough room.
