272cc briggs
BajaHatx272
Hey everyone, I have brand new 4 stroke 272 briggs and stratton off a craftsman select 28'' 2 stage snower. What clutch/tc, chain size etc do I need to get started..I'm planning on using on a baja motorsorts trax tx65 frame20240805_191345.jpgIMG_0201.jpg
BajaHatx272
I have that same kart. The stock sprocket is a 60 tooth and uses a # 420 chain. Figure out what size the shaft is on your engine, as others have suggested. If it's not 3/4" or 1", forget it. You will never find anything to fit. Once you verify the shaft size, buy a 30 series torque converter and install it. I have owned mine since 2008. Have run everything from the stock 196 to a built 224. It's a good kart and has held up well, but you won't get 100' trying to use a centrifugal clutch.
BajaHatx272
Cool, does yours have a hex live axle? Seems like some mods were done at some point.
Some mods done at some point. Boy I guess so. The hex axle was never part of that kart. To the best of my knowledge, Baja Motor Sports never used the hex axle. Mine has independent rear suspension. A 60 tooth sprocket on a hub, with
U- joints on either side and short round axles going to each side. I bought mine brand new in a crate, so I know it's never been altered.
