26cc engine help ?
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
K so I told a buddy of mine that ll fix his 26cc go-ped so I picked it up and tried to diagnose it. I checked for a spark and it didn't spark on its own. So I replaced the plug and it shocked me but won't spark on its own. The plug has to be nxt to something netal for it to start. I can post pictures later but if anyone knows what the problem is that'd be great.
Jake.B
California-USA
Post pictures that will help. Your saying you can hold the plug and pull it and it shocks you but it will not spark?
Jake.B
California-USA
Oh well try grounding the threads or the hex part where your socket fits. On the engine and let the tip hangoff the engine and see iff it sparks. If it does you should be fine.
r97
Measure twice cut once
Massachusetts, USA
Take the hexagonal portion of the spark plug (steel) and hold it up against the engine crankcase or cylinder (aluminum). As long as the hexagonal part of the plug, and the spot you rest the plug on engine are clean you will see if the plug is or is not working.
Jake.B
California-USA
Sounds like its not strong enough to jump the gap. Check all the electrical from the coil and make sure nothings grounding or corroded/rusted. Try bending the metal that the spark jumps to closer to the plug. I would suggest using the old plug if it works so if it is not the problem it doesent ruin the new plug. If this is not it i would guess its the coil. But before you replace the coil i would buy one more plug for it. I had experiance once where i bought a new plug and it didnt work so have some friends.
augidog
ok. if you're being shocked, there's spark. your posts are a bit confusing as to how you're testing.
the plug is "grounded" when it's installed in the head. the spark runs down the insulated middle of the plug and across the gap to ground (the little electrode.)
open the gap to about .024, put the plug in the boot, (hold the boot) and put the end of the plug against metal in a way you can observe the gap, pull the starter, and a visible spark should jump the gap.
robbie
Osceola, Missouri
I'd say that the spark plug has been tested already, and it worked. Back up to the beginning and tell us what your friend's engine was doing wrong in the first place. Was it a classic case of "pull the rope and nothing happens"? The first place you want to check is the fuel system. Before you screw that plug in, put a teaspoon of gasoline or a shot of starting fluid in the hole, then put the plug back in. Pull the rope and see if it starts and then stops. I'd be willing to bet money that's what will happen, and then we'll be talking about a fuel delivery problem.
augidog
hehe...well, we know his thumb will carry a spark, but based on the posts i'm not 100% certain the actual plug itself (and the gap) has been confirmed with a proper test. it seems he may have tested for a spark between the plug-body and the head and got one, but this could also mean there may be a small gap or no gap at all.
also based on what has been posted, (maybe) wrong test but spark confirmed anyway...yes, i agree with Robbie, this is likely a fuel problem. properly confirm the plug's performance, then follow his advice posted above.
