$25.99 10K RPM Clone Flywheel
You never did order it, did you, you prankster. Smh. :yawn:⌛💤
No, changing the shocks on the kart took over. Well, changing the placement of them...
Honestly Im going to hold off a couple weeks to give me time to adjust to the power of this minibike first.
Im having a hard time keeping the front wheel lower than my head as it is.
Then stand way way way back!
NO! That would defeat the purpose of the Darwin Awards. Those that need to exit the gene pool should bend over at the waist and eye the flywheel very closely and “check for cracks”. Cracks should be easy to spot as it’s spinning and blurry. :thumbsup:
Atlanta, GA
Let's pause for a moment and look at this illustration above. Suppose that "spacecraft" contained a human. Being released at hyper-sonic speed from a vacuum into the atmosphere would be like hitting a brick wall. Arguments?
No, because they are both traveling the same speed. Otherwise astronauts could not do space walks. However once they hit the atmosphere they would burst into flames or get peeled apart from the friction. :smiley_omg: 🤮
