yes grav feed will work with it enough to run, generally they can go to 5K i wont push mine that hard (freakboy) soo just run it gently, now is the time to crank it and idle it and see what happens
RPM range should be around that of any other industrial engine (1k-3.6k ish). Is the fuel pump part of the carb like on the briggs twins? if not you could probably get away with gravity feed. Have you cleaned the carb yet?
i wish my carb was complete, its a pre internal pump model....has the casting guts but its not drilled or set up to take a pump... IT SUCKS. i your case even if the pump is soft the bowl float will keep fuel pressure at bay
Hey good job Zane, I'm glad yo got-er goin. (dont be free revving that engine too high of rpms / try to find a good brand of streaght 30 weight oil, not 10-30)
