anderkart
Hey good job man!
Sounds like your old condencer is fine. I think your old coil fired each plug together and you could install an aftermarket (single outlet) coil with your costom homemade 2 into 1 attachment idea.
Your points are probably getting hotter cause you need to install a ballast resistor in-line to your coils + terminal... or better yet just buy a coil for any 1960's 12 volt Ford product and it'll have a resistor already built into it. (your old coil probably had a resistor like old Fords do)
