212cc predator engine
catdaddyhale
I have a predator 212cc engine that will crank and run just a minute then dies. Does anyone have any thoughts?
How about some back story.
Did you just buy it?
Has it sat in a pile of junk in back of the barn for 5 years?
Is it stock, or modified?
Does it have fresh gas?
I'm gonna bet it needs a good carb cleaning.
anickode
S.E. Michigan
Does it RUN run, or just sputter and chug run?
If it RUNS and then dies , you've likely got a clogged up float valve or your float won't open fully. Or your shutoff valve isn't open fully. Your engine is using fuel faster than the bowl is filling.
