212 to replace 5hp flathead
*ryan
the briggs on my gokart is dieing slowly
swapped out carb from another 5hp flattie as the one on there didnt like throttle
my head developed a small crack and is wet after you ride it
once you ride it for a while it will die and not want to start
starting to oose out of places
blowing smoke
gets choppy when riding on not perfectly smooth terrain
will the comet TQ that is on the flat 5 swap over to the predator 212?
Does it have the same mounting pattern on the engine? for the converter and base mount?
Scout
Nutjob
Indiana
Mounting pattern is the same. does the tc mount to a plate that is bolted to the engine?
*ryan
it does not have a plate
i picked up the motor yesterday had a 25% off coupon so was $89 befor tax
i got the new hemi head motor one
if you look at the boxes the old and new have diff part numbers
also the picture on the box actually shows the diff valve cover too
took the old briggs off
bolted the new motor on
filled up the fluids
everything bolted right on
and i did about 2 miles with it last night befor it got to dark
runs great, much better then the briggs
im sold on it
time for upgrades!!
Scout
Nutjob
Indiana
I've been upgrading mine since before I fired it up the first time. Governor delete, intake, exhaust, rod, flywheel, next is a cam and valve springs. So much better than the old flatty.
