212 questions.
Awalker702
Sin City, Nv
There are probably threads about this already but can't find them. I have a 212 predator with air filter, header pipe, jetted, governor removed. Should I install the 18 pound springs that came with the kit I purchased??
No.
your valve flutter (@ whatever rpm it occurs) is your new governor.. or in this case rev-limiter.
You want that!
the next thing that would fail is flywheel or conrod, both of which can destroy your engine completely.
(even hurt driver/bystanders really bad)
Not much WOT is
"no much reason to take the risk" rather than
"not much of a chance for a breaking part" ;)
Half-breeder
"Edit" button removed
From what Ive read/heard, I agree w/ Sid. After the governor is removed the springs are the next line of 'restrictor/governor'. If 18lbs springs are installed... the carb ends up the next 'form' of 'restrictor/governor'... only problem is the conrod(standard/stock) cant handle the abuse of rpms over the springs allowances. Flywheels I aint heard of going out... but realistically I can see it happening w/ the RPMS.
happy_8637
Elkins, WV
:rolleyes:i have the same set up u have. it will turn about 5500 rpm before u float the valves.. i have another one with billet flywheel and 10.8 lb trick springs with stock flywheel pushed it to 6600 rpms with stock connecting rod.. but i did some oil mods to the rod and besides i dont run it like that for a long time
