212 predator kill switch
Awalker702
Sin City, Nv
How do I hook up a single wire kill switch if I've removed the low oil sensor? Do I need to keep the small gold resistor or whatever that is hooked up? Thanks in advance
Yes, the gold box is the relay. The sensor in the block, connects to this.
A momentary push button connected inline to ground, from the relay, will cut the engine dead when pushed.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Ok I do not have pics but here goes. I use the little silver box as a kill switch.
1 Disconnect the yellow wire from the plug going to the block. (the one on the block just dangles)
2 leave the other wire attached to the shut off switch
3 Now run the yellow wire (From the silver box) to the driver compartment
4 attach it to a momentary switch (like a horn button)
5 the other wire from the horn button goes to ground.
This gives you an insant OFF with the touch of a button.
Most aftermarket kart or minibike shutoffs are hold down the button till the motor grounds out. This is much better.
Good luck. post your pics and questions
