212 needs a clutch
btroy
DFW
Hi guys trying to get this cart going. I have an old yellow jacket and have replaced the 5hp B&S with a Predator 212.
The old clutch was seized to the shaft and can not be removed, looked shot anyway, it has a 10 tooth clutch and a 60 tooth rear sprocket.
It never had a chain when I got it but what I need conformation/guidance with this. Would this setup work?
Fun Kart Centrifugal Clutch 3/4" Bore 10 Tooth Chain #40 #41/420. I assume this is the one I need. Tires/wheels are 15x6x6.
Any assistance would be appreciated.
Poboy kartman
Senior Moments Member
White Settlement Texas
Yes, the odds are good that's what you need, but measure the rear sprocket tooth tip to tooth tip and make sure it's 1/2"....then measure the thickness to determine chain size.
DFW is a big place....but GoPowersports is in Keller and they're a great place to get parts. That being said, I just bought a clutch from them and had it delivered for $6...
But a larger order. or something big and heavy...and I can drive there in under 20 minutes.....sooooo.....
EDIT: PM me! I might want that Briggs! Neer mind, I'll PM you!
DOUBLE EDIT: If it's not too hard to change out, a 72 tooth axle sprocket might be easier on clutches.
btroy
DFW
can I just not upgrade to a better 10 tooth clutch to handle the 60 tooth sprocket? or is there such a thing?
After tearing into it going to need bearings for the rear, might as well replace the brake as well.
Going to run 15x6 tires all the way around.
Poboy kartman
You don't necessarily need a better clutch. A 10tooth. puts you at 6:1 and 15" tires aren't that tall, but that's right on the edge. You can get a cheap one and just see how it does.
btroy
DFW
ok will go that route and see how it runs, should do fine since this is my first cart,
