20hp Briggs vanguard pto
Mrflyingdonut
I have a 20hp Briggs vanguard and an old cub cadet transaxle I want to use to make a kart of some sort. Does anyone know where I can get a flywheel PTO adapter for the engine to drive the transmission?
Sent from my SM-G950U using Tapatalk
---------- Post added at 06:17 PM ---------- Previous post was at 06:00 PM ----------
Here's some pictures
The other side has the shaft you need to attach to. Probably a 1" keyed shaft. Attach a torque converter between it and the trans axle. Might have to mount the engine sideways but whatever works.
karl
North east Ohio
Cub cadets drive off the flywheel, driving off the PTO shaft will reverse the direction of travel, if your into 3 reverse gears.
Mrflyingdonut
Awesome info on the adapter, does anyone know of a clutch I can use. Or should I just rebuild the old one and use it
