Very slick!!! You did a great job on this build. One of the cleaner and more professional ones I've seen![]()
Thank you sir!
I am curious about your brake caliper. I noticed in one of your pics that you have the bleeders on the bottom and your lines on the top. I have same set up with dual lines. Maybe that why I can’t get them to bleed. Any info on this. Or how did you bleed them. Thanks.
I am building the other barstool in the contest.
I reverse bled and pushed fluid up through the master cylinder. They were a royal pain to bleed the conventional way. Even with reverse bleeding it took quite a bit of time to clear all the air.
I see you are using an MCP master cylinder. That should be a little bit easier than the hand lever master cylinder I used. I had to use shims behind the brake pads on the billet caliper because the hand lever master cylinder does not have enough displacement to move the pads a bunch. The cast caliper you are using is easier if this happens because it has adjustment screws.
That’s what I am going to try. What about the bleeders on bottom. I always thought bleeders on top. But I did see one vid where guy said check with manufacturers. So I was just wondering. Thanks man.
