JMINDY
I'm not at the bumper stage yet of the build, but trying to plan ahead...
I thought I'd post some ideas and get some feedback on how to go about making & mounting them.
Originally I was going to build my own using 1/2"(ish) solid bar, but was concern with weight, durability, and time/how to fabricate. So, put it on the back burner and worry about it later, right?
Then I was cleaning out the garage a few week ago and found these remaining pieces of an old exercise machine that was scrapped out long ago. Hmmmm....
REAR BUMPER...
Here is what I am aiming to imitate...
Here is what the backside of the kart looks like.
1. I want the back bumper to be mounted off of the center section of the frame, NOT on the roll-bar or the angle iron for the hood support as the body panels are mounted to them.
2. I would like the bumper to be easily removable or possibly hinge down in order to be able to get the hood on and off easily.
3. With the shape of the bumper, the hood support bar has to go between the top bar and the bottom bar of the bumper.
Here is the pipes with a rough mock up...
And here is how I was thinking of fab. a rear bumper with them...
Weld a smaller diameter pipe (green) straight up from the frame. The ends of the top bar would pin to this and the other end is inserted into it's upright bar. This would allow the top bar to separate from the rest of the bumper. Then the remaining portion could unpin from the bottom of the frame. Bumper extensions would need to be made to protect the roll-bar and body panels.
So... any problems with this? Any better ideas?
NOW FRONT BUMPER...
Here is an idea with the pieces I have... a push bar of sorts...
But no idea on how to go about mounting it...
Your thoughts, imput, concerns are appreciated!!!
REAR BUMPER...
NOW FRONT BUMPER...
