2013 - Turbine powered hydrostatic launch craft
sp_1989
Pre-builder
Southwest Iowa
HA! Not really, but made you look! :lolgoku:
Here's my humble submission.
But if anyone DOES have a small turbine for sale...
Yeah, dang- I almost dropped my laptop! LOL- Good luck, and happy building. Maybe, you can get the older fella in the pic with you, to help too.:roflol:
gvfc2
wishing i was living
Tacoma,wa
maybe resize the pic alittle. takes up more than my screen has.
haha what type of turbine?
sp_1989
Pre-builder
Southwest Iowa
New parts
Ok, here's the ordered parts:
Northern Tool: #13828 Front wheel hubs
BMI Karts: #400281 Brake caliper
#AZ1828 Brake rotor
#400045 Rear axle
(One note, the axle did not make the shipment. I called BMI and they sent me another axle that DID make it. Somewhere in UPSLand is a 1" x 45" steel shaft. Thanks BMI! :wai: )
Surplus Center: #1-3517 Seat adjuster set
#1-205-16-P-C Pillow block bearing
#13-CFR-6 3/8" rod ends
sp_1989
Pre-builder
Southwest Iowa
Used parts
Here are some of my used parts:
From a John Deere 185 Lawn tractor:
Rear wheels, Steering components, hydrostat (maybe??)
From a couple John Deere rear-engine mowers:
Rear wheels, pedals, linkages, gas tank
(Note pic of rear wheel hub, this is for a 5 bolt wheel)
Various industrial carts:
Steel tubing
sp_1989
Pre-builder
Southwest Iowa
CAD pictures
I guess one of my goals with this project is to have it all drawn up beforehand to try to minimize screw-ups. Plus, it's the challenge of having an accurate computer model itself that intrigues me also.
SO, below is the current state of affairs.
I need to still:
-decide on an engine (looking at Honda GX200)
-make front wheel adapters
-figure out front spindle design
-test Deere hydrostat on its side
sp_1989
Pre-builder
Southwest Iowa
Hub adapters
Ok, so I drew up some wheel hub adapter plates and took them to a local machine shop. They used a laser cutter to cut them out, PRETTY COOL! They turned out better than I expected.
sp_1989
Pre-builder
Southwest Iowa
Engine found
Moving ever so slowly along...
I picked up a slightly used snowblower at a school garage sale. It hasn't been used much but hadn't ran for a while. When I got it home, I sprayed some ether in the carb and pulled the rope. It fired right up and ran for a second or two, so that's all I wanted to check. I took it off the blower and took the heat housing off and noticed something I didn't realize before. Snowblowers don't have air cleaners. Apparently there isn't any dust in the air in the winter. Go figure.
So now I'm looking for an air cleaner. Unfortunately the Deere mower I had didn't have one either. Any ideas?
WOW! That intake system looks overly complicated... Am I correct in thinking that the throttle adjustment (the red knob) is covering the carb inlet? If so, that would, obviously, need to be removed to fit an air filter...
The red knob just turns the choke plate. Good engine- that's an L-head Tecumseh. Look for numbers on the shrouding.
Once you have determined the exact engine (maybe H40,or H60, hard to tell from pics) you should be able to cross-reference similar engines that used an OEM filter.
sp_1989
Pre-builder
Southwest Iowa
It's kind of hard to tell about all the numbers, but this is what I THINK it says:
HM80 15514CF SER 9186C
I'm assuming the model is HM80. Horizontal shaft, 8.0 hp?? (Not sure what the M means)
