mark123
This is not go kart related but I couldn't get any responses in the sled forums so I thought I would ask here. I recently put a 200cc clone into my young fellas arctic cat 120 mini snowmobile and when I did it it had tons of power, it would spin the track with me (200lbs) and take me to 20mph. Now after approx 10 hours of use it will barely take my son (50lbs) to 14mph and won't make it up hills with him. Throttle is operating fully and the choke is off completely and I also tried removing the air cleaner with no change. I did a compression check and it is only showing 70psi and with 2 teaspoons of oil in the plug hole it is showing 85-90psi. There is no burning oil smell at all. Could this be a valve clearance issue? When I removed the govenor I made up some shims for the valve springs from washers approx 0.70" thick for more spring pressure and re-adjusted them to factory specs, could 1 or both of them come out of adjustment or something. I assume if the rings were bad I would be smelling burning oil. Thanks for any help
Contrary to popular belief, any engine at that price point has a definite break in procedure; having stated that you already tore it down, you've pushed the rest of us into no man's land. We weren't here, and we didn't see just what you did.....
