2002 Manco QuickSilver 2x5 GL won't run
Hapgilmore10
Turlock, CA
Just purchased a 2002 Manco Powersports 2x5 GL and engine runs fine. Just won't move, just falls off. I tried an 8 tooth sprocket and it didn't work. This is what it came with, just want to see what should be on this kart or what would be best. Plan to make this puppy that baddest on the block.
Issues: -420 chain won't stay on
-3/4 sprocket built in-key 9 tooth is worn down
- Large sprocket is worn down.
Im having trouble finding the right sprocket anywhere on the net. Will a 10 tooth work?
KartFab
Dallas, TX
Here is axle sprocket??
http://www.gopowersports.com/mobile/Product.aspx?ProductCode=6282-9338
You sure Jackshaft is not a 5/8" sprocket?
http://m.ebay.com/itm/330976046410?nav=SEARCH
Might want to try americansportworks.com and look up the parts manual there. Should be easy once you locate the manual to find parts.
Gokartsrus.com also carries a lot of manco parts.
10t will "work" but you will not accelerate fast.... But you will have a higher top speed.
Make sure you replace both Jackshaft and axle sprocket at the same time. Then put on brand new 420p chain.
I'm assuming you already know this, but you need to adjust chain tension by loosening the bolts holding the motor mount to the frame. Should be about 1/2" of play in the chain them tighten the nuts/bolts.
Also, you can use a straight edge like a ruler against the axle sprocket to make sure the axle sprocket lines up perfectly with the Jackshaft sprocket.
A lot of manco sprocket hubs have a single screw that clamps the hub to the axle. Make sure this is tight so the sprocket won't move back and forth. Washers can be used for Jackshaft sprocket adjustment.
