20$ big block
jmaack
Just picked it up. I think my cc100x is screaming for it.
karl
North east Ohio
jmaack
I already have a nice honda washer. Has compression just weak SPARK. Plug and cylinder not oily. Oil looked meh but wasn't black and is in it. I wish it was a cat pump but oh well.
I want a big block bike but will go with a larger predator.
jmaack
It runs when pouring gas down it. Changed plug, cleaned main jet, bowl was full of gelled gas and green mess. Couldn't get emulsion tube out its frozen up in there. But it's a cheap big lock and nice pump.
jmaack
Nice looking and still correct lash.
jmaack
Running in to a weird issue. Has to be coil related i think. Very hard to start on gas, one pull on propane. However with test light on plug it lights when plug is sitting on the tire. I can also hold plug in my hand and am still getting a slight shock. Tried 2 new plugs same outcome.
I have purchased a rebuild kit for pump.. I dont know what i am going to do with it, but it is way nicer than my simpson 3300 2.5 gallon gc190 sprayer.
Going to pull cover and check coil etc tomorrow. The design is horrible as the engine has to be loosened to do this and also just to remove the carb looking at new carts. SMH
jmaack
Went through carb. It was disgusting. Got all pieces out. Put back together and started on first pull. This is a definite win.
