2 stroke stalling when backing off
jman231994
Australia
Hey guys, after a few hours fiddling with the Victa I've given up on just trying to guess what settings I need to change.
The problem is that it stalls after it returns to idle and its also a little bit smoky, it also doesnt seem to be revving out properly. Whilst I havent fully ruled out the fuel my friend and I weakened the mix with some fuel to try and see if the issue disappeared, no change.
The engine will idle and rev poorly with the jet fully shut on the carb which I found confusing as I expected it to fully block out. I accidentally left the fuel tap shut at one point and the engine became much smoother and seemed better as it leaned out, however it still would stall.
The carb is an older tecumseh with adjustable jet and idle valve thingy. The engine is a Victa 2 stroke designed to run anything from 25:1-50:1 . The current mix would be close to 30:1
If any of you guys know what might be causing it or how to better tune the carb I'd love to know, I'm about to begin reading the 2 stroke tuners handbook in search of an answer anyway.
Thanks
fowler
Bullsbrook West Aus
i assume u have tryed removing the air filter
if it ran smoother when starved of fuel then it sounds like lack of air
is the float working as it should?
have u pulled it apart to see if the adjustable jet is accually adjusting and the fuel isnt bypassing
jman231994
Australia
Yea, havent made up an air filter yet so its just straight
Ill look into how the carb works see if i can adjust something to do with the air though. And ill take the jet out when i get a chance to see if its working right, float should be fine, its not flooding
