2 stroke? forward reverse
Swabbster
i love 2 strokes! i want to build something with one maybe a lawnboy engine or something modded out lots, and run a comet tav2, but i know a 2 stroke can be started backwards, so maybe a starter generator to start it forward or reverse, but i know the driver is bi directional but what about the driven i would think it would spin the movable plate a 1/3turn to the other cam buttons but would that brake the spring, would it work the same just not shift or what? i am not worried about shaft size or mounting i get machining work done for free and i can figure everything else out, the wiring id use a 3 way switch that clicks back, the middle does nothing and either way with run two different circuits, just flip one way for forward and the other way for reverse,
FatCat
2 stroke Addict!
Ottawa, IL
you could consider soarcing parts for this from a golf cart. the old 3 wheel Harley Davidson carts ran backwards for reverse.
Several of them did. None of our regular CVT driven units can be run backwards, due to the direction of the spring winding. I've never played with one from a golf cart. Snowmobiles have reverse AFTER the CVT, so that's out.
kendelrk
redneck engineer
westland michigan
This may be more work than its worth, but what about making a plate to go with the tav2 backplate with like a basic gear shift from a bicycle but bigger, when you pull the cable it will move the belt to another driven that's spring winded backwards, and then you can fab another handle to pull it back to the regular driven
