2 Stroke engine questions
ballinchestr
Grease Monkey
Massachusetts
I'm trying to put a 36cc chainsaw engine on a scooter. Mounting is fine, engine is operable, but I have 2 questions.
How do I attach the fuel tank? There IS a primer bulb, and a tube coming out of it. I assume this goes to the tank with the main line, but I don't know how/where to attach it.
What's the crankshaft diameter for a chainsaw like this? its a Craftsman, bought it back in '06. I'm assuming it's 10mm...
Thanks.
fowler
Bullsbrook West Aus
there should only be 1 line
it is likely the primer one u speak of
u can never assume
makes *A$$ out of U and ME
cant u measure it with some verniers
ballinchestr
Grease Monkey
Massachusetts
There's two lines coming from the primer. one goes to the carb, the other goes somewhere I don't know. should I install it in the tank with the main line?
not very familiar with 2 stroke
Although I'm not a 2 stroke guy, I do know 1 or 2 things &, IIRC, there should be 3 lines:
Line 1 goes from tank to bottom of carb
Line 2 goes from top of carb to primer bulb
Line 3 goes from primer bulb to tank
Of all the small 2 strokes I have (about 4) they're all setup the same way
firemanjim
Just kartin' around....
Houston Texas
:iagree: yep yep..... my weed wacker,chainsaw,and leaf blower all have 2 lines out of the tank. One to carb, one from primer. And then the one from primer to carb.... #1 line feeds carb,main fuel source. #2 is what the primer sucks fuel from. #3 feeds carb from primer, for initial start up....
KartFab
Dallas, TX
use what is called a fuel tank joint. The hose goes on the joint, and you secure it with a tiny hose clamp.... the joint goes through a hole in the tank, and you can use a small washer and nut to secure the joint to the other side. There is an o ring built into the joint so it shouldn't leak fuel.... i hope. The joint is like $5 and you can pick it up at any lawn mower/small engine shop or order online. It also has a built in filter on the joint. Also, poke a small hole in the bottle lid so it wont be under vacuum and cause your engine to quit.
http://www.ebay.com/sch/i.html?_trk...joint&_nkw=fuel+tank+joint&_sacat=0&_from=R40
machinist@large
West Michigan, 49331
That's an add name; the industrial name is a bulkhead connector, or fitting. It gets used for a lot more than just fuel tanks; think high pressure pneumatics and hydraulics.....
