2 stroke engine help
flowerman
junior member
England, surrey
Hey
So I am building this for the build off http://www.diygokarts.com/vb/showthread.php?t=15269
But I am having a few problems with the engine it is just a simple 2 stroke mini moto engine, but there are a few problems. This is the engine http://www.petrolscooter.co.uk/engine-complete-49cc-air-cooled-mini-moto-1.html
It runs ok and I started it about a week ago and it was fine apart from a little Gray smoke and then some oil coming out of the exhaust. Then I come along the next day and I try to turn over the engine and it is really difficult, and the pull start is bending it is so hard to turn over. Nothing like the day before. I took the spark plug out and had a look at it and it was slightly green, so I thought the mix may be wrong... It says to run the engine on approx 30-1 and that's what I did. I am just a little worried that something's happend to the engine:ack2::oops:
At the bottom of the second page of my build thread there is a video of the engine running.
Thanks
Please help
klicky96
Sandusky, Ohio
Okay, is the spark plug like a greenish-white? Was the thing sitting around water? Out of rebuilding weed-wackers, chainsaws, and well, 2-stroke engines, this sounds like a case of water. If it is water, it is a simple fix actually. Just take the head off if it does not have a detachable cylinder. Clean the cylinder out with a soft rag and some engine oil. Clean up the piston because it would have had water on it also. Then put it all back together. It'll only take maybe a half-hour.
augidog
hate to say it, but those engines are pretty cheaply made, and any lack of lube will toast the con-rod bearing/bushing in short order. how does it spin with the plug out?
fuel-ratio (gas/oil) is not the same as fuel-mixture (fuel/air)...
you adjust the mixture by removing the carburetor slide and moving the circlip on the needle, which has either 4 or 5 grooves in it...it sounds like you may be too lean, which means you'll move the clip "down" one slot at a time until you get smooth operation. you'll need some good needlenose pliers and maybe reading glasses too.
btw-personally, i'd never exceed a 25:1 gas/oil ratio with the chinese 2-strokes.
