2 Stroke 26cc won't run
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
I may have screwed up, or maybe not. I'm not sure. Either way, I couldn't get my mom's weedeater started the other day, so I tore apart the carb and cleaned it w/o first removing the H and L speed mixture screws, so I took it back to my dad's and thoroughly cleaned it, soaked it, cleaned it, etc. So today, I put the carb back on and now I can't get it to run.
So far, I've:
Set the H speed screw to 1 1/2 turns out
Set the L speed screw to 3/4 turns out
Adjusted them with offsets of 1/4 turns here and there
Snapped two screws on the crank cover, I'm not freaking out just yet
It'll start up with carb cleaner on choke, and for some reason, it'll rev up around 8000 RPM, and be extremely loud obviously over revving. Could this be an air leak in the crankcase ? I can't really check because I can't get it to run stable enough. And I tried to drill the two broken screws out, but I couldn't. Can you somehow screw the case cover on tighter with those self tapping screws? Any help is appreciated.:2guns:
Brandon1023
needs an oil change
I'm thinking that's it. I used a drill with a certain hex key bit and I twisted not only one, but two screws which hold the crankcase cover on. My guess is that it's drawing air, but shouldn't this cause it to run lean and slow? It was revving faster than 8k, somewhat surging. I can't get the screw shafts out of the slots as the heads broke off during tightening. Is there a screw that can be used to drill right through the cover and in to the block to fasten it?
Br@ndoM@n
Dude with a gokart, a MIG
New Mexico (Not Dirty Poor Mexico, NO HABLA ESPANO
Hows the fuel lines? It will do that if u got a bad fuel line. I replaced my lines on my Weedeater XT600 cause it was doing the same thing and was good afterwards. I know my plastic case is also part of the crank cover so maybe busted bolt making u lose compression?
Brandon1023
needs an oil change
Yup- my money's on a bad 'case seal. Pulling air in where it shouldn't will cause insane revs in a two-stroke.
Not only were you right about the seal in the crank case, but there was also obvious air getting in through the intake, because I put the stupid heat dam/shield on backwards. The self drilling screws are cool. Never used em before, but will definitely be using them again. I wish 2 Strokes werent so picky, cuz we gotz a new problem going on.
It runs on idle and starts up in a few pulls, but when you give the trigger a slight squeeze, the engine will rev to around 8.5k in the pain zone on the ears. I know that's obviously not normal, and this is going back to my mom's house where she doesn't pay attention to the throttle, let alone visualize (or at least try) the speed at which a crankshaft in a 2 stroke spins. Soo, I need to be sure that if/when she hits the gas all the way, it doesn't overrev. I turned both screws out 1 turn and turned the idle speed screw a bit since it was stalling out. At one point, hitting the gas all the way would result in it bogging out. After maybe a turn and a half total of the H screw, it would rev insanely high again. I know this is simple stuff, but 2 Strokes are just not my thing.
Don't feel bad, I'm still learning about them too. Dumb question- Have you got a few inches of string out for your testing? That acts as a "load" and helps keep RPM reasonable.
Brandon1023
needs an oil change
Actually, that's great you asked that, because it's running with nothing attached except the curved shaft. I didn't think of any harmonic balancing which is stupid. My mom got pistoff at the spool since it wouldn't feed automatically <fp> and took it off. I'm not trying to rev it out at WOT, since I'm sure she doesn't plan on running it that wide to cut some grass by the backyard fence fence. I've just seen the guys work on 2 stroke edgers and whatnot, and it seems to me like he has it at wot while he has his head in a cloud of 2 Stroke smoke, adjusting the carb. I thought at wot, it makes some popping sound and doesn't rev any higher. Dunno, anyway, Might as well let my dad get some use out of his ex wife's weedeater tomorrow around here XD
