Brandon1023
needs an oil change
I may have screwed up, or maybe not. I'm not sure. Either way, I couldn't get my mom's weedeater started the other day, so I tore apart the carb and cleaned it w/o first removing the H and L speed mixture screws, so I took it back to my dad's and thoroughly cleaned it, soaked it, cleaned it, etc. So today, I put the carb back on and now I can't get it to run.
So far, I've:
Set the H speed screw to 1 1/2 turns out
Set the L speed screw to 3/4 turns out
Adjusted them with offsets of 1/4 turns here and there
Snapped two screws on the crank cover, I'm not freaking out just yet
It'll start up with carb cleaner on choke, and for some reason, it'll rev up around 8000 RPM, and be extremely loud obviously over revving. Could this be an air leak in the crankcase ? I can't really check because I can't get it to run stable enough. And I tried to drill the two broken screws out, but I couldn't. Can you somehow screw the case cover on tighter with those self tapping screws? Any help is appreciated.
So far, I've:
