Time to spoil the grandkids. Found this old Fox II locally and bought it knowing it needs a lot of work. So far I've discovered every drive component is shot, and that's not a surprise. I bought all new, including a new electric start Duromax 7 hp. The list includes a new 70 tooth sprocket, a new 12 tooth Hilliard extreme duty centrifugal clutch, a new #35 chain, new 14.5/70-6knobby tires and tubes, a new hydraulic disk brake, new seats and new seat belts. (Whew!)
The kart will be used on relatively flat ground (6 acres), part dirt, part gravel, part grass. The goal is just fun for the kids, but grampa may get to drive it once in a while.
While I'm at it, I'll strip the frame and paint it, replace bearings/bushings, tighten up the steering, and no doubt other things as needed. Advice welcome!
Tom
Tom
