Brandon1023
needs an oil change
I'm confused here. I thought all engines of equivalent size would have the same shaft size not only in dia., but in length as well. I need to order a pressure washer pump for a friend, so I'm trying to find out which one will fit the shaft of his engine which by the way is a Honda GC 190. I have the same engine which is about 7 years newer, but looks identical.
Now, when I pulled the pump off mine for comparison purposes, I found the shaft was not only at least double the length of his engine, but it was also considerably smaller in dia. I took an old max torque clutch from my 6.5 Techumseh engine and it fit, giving it a shaft size of 3/4". I tried putting the clutch on his engine's shaft, and it didn't fit. I don't think the shaft is quite 1" in dia, but it's not 3/4", either. I know that I can measure it with a ruler, but 1. I'd have to look around my house for one, and 2. I'm not sure if this shaft is going to work, buying a new pump since it's a much shorter shaft. Any help asap is appreciated as he seems to be getting impatient a week later.
Below is a picture of my engine on the right with the 3/4" clutch on the shaft and to the right is his engine with the unknown shaft size.
