2 hp engines and is it worth it
magicdragon
ive just recently come in to owning a 2 hp Briggs and Straton engine, and was wondering if it would be worth it to use it in my go kart project
or would i better off buying something bigger
Badot
If you don't expect it to go very fast, 2 hp would be fine.
I would recommend building the frame so it could handle higher loads as well as a larger engine in case you want to swap it out though.
CaptCanadia
Acton, CA USA
I don't think so at all. I've recently got into karting and the first engine I got was 6 HP and that was still too slow. I would start out at a minimal of 5 HP, otherwise you're not gonna have fun and just waste your time and money. Honestly.
Russ2251
AZUSA:Powered by LAWN-BOY
Magicdragon already has the engine. Why not use it? Would be a waste no to.
If he decides he wants something bigger he can always make the change.
In answer to his question ...Yes, it would be worth it.
Also, hp does not necessarily translate into speed.
dave1701
Good for 100,000 Miles
MICHIGAN
You can definitely have fun with a 2.5 engine. If it works, use it. He can always upgrade later.
kendelrk
redneck engineer
westland michigan
itd be cool to start with, what if it breaks? or somthing happens? its better to start out with that 2 or 2.5 and test it, then youll know how it is
